Problem calibrating a LCD
COW Forums : DaVinci Resolve
Francois Xavier
on Sep 11, 2014 at 5:06:52 pm
CalMAN 4.5.6 / Windows 7
Calibrating an LCD using burned AVSHD Blu-Ray
the source setings in "Optical Player ... (manual control) but I appear to be stuck with the Generic calibration DVD workflow !. Can't change it on the left tab
At the gamma step I don't have the bar with the numbers at the bottom of the interface, under the curve.
That bar from 0 to 100 is missing
I can't "indicate " to Calman the value pattern the metter is analyzing. It doesn't present itself as I see it on the step bye step pdf
why ?
thank you to help me
Juan Salvo
Re: Problem calibrating a LCD
on Sep 11, 2014 at 8:18:34 pm
This might be best suited to the calman support forums on their site.
http://JuanSalvo.com
http://theColourSpace.com
