Edit with DaVinci 11 & Multicam
COW Forums : DaVinci Resolve
Isaac Bergada
on Sep 5, 2014 at 10:57:21 am
Got a quick question regarding Resolve 11 and Multicam. Once imported a fcpxml I lose the angles inactives, leaving only one active clip. Has anyone found a solution to keep the others angles? Any help is greatly appreciated.
Theodore Miesner
Re: Edit with DaVinci 11 & Multicam
on Sep 7, 2014 at 7:10:35 pm
Hey there Isaac! I've had that same issue. Luckily the fix is pretty simple. In your NLE (I am going to use Premiere Pro as an example) select all of your multicam sequence then right click > multicam > flatten. Re export your XML and you should be golden!
shameless plug: If you want more sweet Resolve tips be sure to check out my youtube channel https://www.youtube.com/channel/UC_4HXushRwS_9b1JdRFYVgw
Hope that this solves it for you,
Theo
Isaac Bergada
on Sep 8, 2014 at 8:40:09 am
Thanks Theodore, both FCP7 XML as FCPX XML will automatically make the collapse of video tracks.
Because I'm looking for just the opposite. To keep all the video tracks when import XML to Davinci.
Isaac Bergada
on Sep 19, 2014 at 10:08:43 am
Hi guys, excited to try the new version DaVinci Resolve 11.1 Beta ( with multicam support) :
https://www.blackmagicdesign.com/support/download/15010/Mac%20OS%20X
