XML Roundtrip
COW Forums : DaVinci Resolve
Gina Sarentino
XML Roundtrip
on Aug 30, 2014 at 12:30:46 pm
Hey all,
Im working on a project that has Red Dragon 5K footages. Now I import my xml from premiere into resolve and it all works fine, I then grade and when I go and export the roundtrip XML back to Premiere and when I playback the footages in Premiere they appear to be laggy. Now I even have this issue with my Canon 5D mark 3 footages as well. When I export them out of Resolve I export them as Quicktime 8bit RGB, why do I get this playback lag in Premiere? And another small note, when I render out these graded clips from premiere they playback just fine. So my issue is only the playback in premiere. Any help will be appreciated, thanks.
Joseph Owens
Re: XML Roundtrip
on Aug 30, 2014 at 7:11:07 pm
Typically most NLEs want to see Y'CbCr codecs -- if you are using an RGB codec like Apple Animation for example, there will have to be a conversion and/or render before the media can be played in real time from most editing timelines.
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
