Pages Tab not showing in Davinci Resolve (Macbook Pro Retina)
COW Forums : DaVinci Resolve
Aaron Budiman
on Aug 27, 2014 at 11:05:09 am
Hi guys, I recently just picked up a new rMBP for myself, and I have a very noob problem as I just started using OS X. :)
As you can't see, I have no clue where the pages tab is.
P.S. My display scaling is set to best (retina)
Can somebody please help me? Thanks in advanced.
Robbie Carman
Re: Pages Tab not showing in Davinci Resolve (Macbook Pro Retina)
on Aug 27, 2014 at 7:29:13 pm
change your display settings to "more space"
Robbie Carman
Colorist and Author
My Books
Online Training
Twitter
Blog
Mixing Light Powered By The Tao Of Color
Don Eitner
on Sep 14, 2014 at 8:55:16 am
On the View menu go down to User Interface Layout and then click Show Window Frame. You can then resize (i.e. maximize) the window using the standard OSX "green circle" button at upper-left of the window and you should see the MEDIA, EDIT, COLOR and DELIVER buttons across the bottom.
I had the same issue here on a monitor which is only 1600x900. Unfortunately it seems you need to click the green circle/maximize button each time you launch, though you should not need to seek out and click Show Window Frame each time.
Don Eitner
Aaron Budiman
on Sep 14, 2014 at 8:58:39 am
Thank you very much for the tip Don! :)
Larry Herbst
on Mar 24, 2015 at 8:09:00 am
Thank you for this.
It amazes me that a software developer can release a product (even a free one, and yes I'm grateful) where a certain significant population of users will immediately crash right into a wall on first use. I spent an hour just trying to figure out where all the functionality was, downloaded the user manual (which of course just says look, the pages tab is right there, but it's not) and found myself ready to write off the whole project.
I'm already expecting Resolve to be a painful learning curve, since they hid the keys to the kingdom right from the get-go, and obviously are oblivious to how the most basic functions might not be readily apparent.
Truly, if you hadn't laid out simple step-by-step instructions, I'd have given up and gone to bed.
I thank you sir.
josh steinbauer
on May 27, 2015 at 5:07:21 pm
yeah, had the exact same infuriating problem. watching all these tutorials, but had no way to get started because my screen didn't have the same tools. bad form, Black Magic.
Aaron Budiman
on Sep 14, 2014 at 9:00:47 am
Thanks a lot Robbie! :)
