Failed Render
COW Forums : DaVinci Resolve
jim bachalo
Failed Render
on Aug 9, 2014 at 10:27:23 pm
Out of the blue getting this error message. had no problems rendering to exact same path before. WTF?
DaVinci Resolve is unable to render to the selected path "/...." as it does not have write permission. Please ensure that DaVinci Resolve has write permission for the path selected and the first drive you list in Preferences.
You should follow me on Twitter here. My latest work
Martin Noll
Re: Failed Render
on Aug 13, 2015 at 7:32:08 am
Did you find a solution? I've got the same problem (V11.3.1, OSX 10.10.2).
Dwaine Maggart
Re: Failed Render
on Aug 13, 2015 at 3:56:46 pm
If your source files are QuickTime, or you are rendering QuickTime files, illegal characters in the file name or path name of the source or render files can cause this issue.
Dwaine Maggart
Blackmagic Design DaVinci Support
Marc Wielage
Re: Failed Render
on Aug 13, 2015 at 8:34:46 am
Eh... repair permissions? Check to see if the drive is partially locked in the Finder? Make sure the drive is available in the Scratch Drive settings?
Jan Martens
Re: Failed Render
on Aug 19, 2015 at 8:03:43 pm
There are no obvious illegal characters in filenames (maybe in Quicktime metadata?).
Repairing rights was the first thing I did. No success. Other apps don't have any problems to write to that path.
Dwaine Maggart
Re: Failed Render
on Aug 19, 2015 at 8:15:32 pm
Jan, are you working with Martin, or a different scenario? Windows or Mac?
Dwaine Maggart
Jan Martens
Re: Failed Render
on Aug 20, 2015 at 5:30:06 am
Yes, same Mac workstation, 2 different student projects but using the same source material.
Joseph Owens
Re: Failed Render
on Aug 25, 2015 at 3:55:04 pm
Sometimes the error message has nothing to do with the situation and the application is sjmply making a best guess. You will get this notification if you have run out of space on the disk, as well.
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
