Balancing colour of the trees in different shots :)
COW Forums : DaVinci Resolve
Chris Cory
on Aug 3, 2014 at 11:28:55 am
Hey
I have been using resolve for bit and im starting to get my head around it.
Though does any one have a good suggestions for balancing the colours of the leafs on the trees?
Here is an example.
Any advice or tips would be greatly appreciated.
http://f1.creativecow.net/file/7812/7812_eg.jpg.zip
Chris
Aurie Anden
Re: Balancing colour of the trees in different shots :)
on Aug 12, 2014 at 9:28:26 am
I keyed the warm greens and then shifted the hue to match your cooler greens. It was a rather clean key so I think it shouldn't be too much trouble for you.
7860_7812egbal1.5.1.jpg.zip
Chris Cory
on Aug 15, 2014 at 5:37:37 pm
Hey
Thanks again for this.
Can you go into a bit more detail about how you did it, getting the trees the same colour is something I have not been able to do.
What did you use to shift the hue?
Thans Chris
Aurie Anden
on Sep 4, 2014 at 10:48:54 am
Hi Chris. After getting a clean key of the warrm greens, I just used the "Hue" control to shift the color. That control should be in the color page below the color wheels. It's right under the "Gain" color wheel. :)
Use that in conjunction with saturation until you get the color you want.
cheers
Chris Cory
on Sep 4, 2014 at 10:33:35 pm
Thankyou!!
