3D Output LUTs- apply on node vs in Project Settings
COW Forums : DaVinci Resolve
jim bachalo
on Jul 27, 2014 at 8:00:49 pm
When using 3D Output LUTs for stylistic reasons, is there any difference(in the final output) between applying them at the node level vs in Project Settings?
If not, when should you use each approach?
You should follow me on Twitter here. My latest work
Andrew Shtern
Re: 3D Output LUTs- apply on node vs in Project Settings
on Jul 30, 2014 at 7:20:15 am
There is no difference. However, node approach allows you to fine tune the result, by adding adjustments after the LUT.
Andrew Shtern
Editor/Colorist
The Coffeepost @Kiev, UA
