Bypass Output LUT
COW Forums : DaVinci Resolve
Daniel Christie
Bypass Output LUT
on Jul 11, 2014 at 12:57:34 pm
Is it possible to bypass the output LUT on a per clip basis? I'm working on a project that is primarily S-Log3, so I'm using an S-Log3 to Rec709 output LUT but have a few assets (titles etc) that are not log.
If I were working in ACES, I could do this with an inverse IDT.
Cheers,
Daniel
Eric Johnson
Re: Bypass Output LUT
on Jul 11, 2014 at 6:23:45 pm
I think the only way to do that would be to add the LUT at the end of each Node tree... and disable the Output LUT...
eric b johnson
online editor | colorist | workflow
http://vimeo.com/ebjohnson/colorreel
John Sellars
on Jul 13, 2014 at 5:59:03 pm
What about adding the LUT to a track node, then turn it off with a static mark?
