Is it possible to view the all pictures as monochrome while setting the contrast levels?
COW Forums : DaVinci Resolve
Andreas Ahston
on Jul 5, 2014 at 4:00:36 pm
It's easier to se if the contrastlevels are similar if there are no colors. So I'm wondering if there is an option to disable the colors while setting the nodes for the contrast, and then turn them back on to do the color work afterwords? I realize that I could just copy paste a node with no saturation onto all the clips. But perhaps there is an easier way, or perhaps this is not really a good idea. Any thoughs.
Paul Provost
Re: Is it possible to view the all pictures as monochrome while setting the contrast levels?
on Jul 5, 2014 at 5:14:13 pm
You could switch you broadcast monitor to monochrome
http://www.filmandtvcolor.com | colorist | Los Angeles, CA
Twitter: @4kfinish
Eric Johnson
on Jul 6, 2014 at 7:33:53 pm
What Paul said, but if you want an in Resolve solution, you could set a Track correction using the Monochrome setting in the Color Mixer.
eric b johnson
online editor | colorist | workflow
http://vimeo.com/ebjohnson/colorreel
