ML RAW Workflow - Problems Rendering Desired Frame Rate
COW Forums : DaVinci Resolve
Drew Angle
on Jul 1, 2014 at 5:34:00 pm
I'm trying to iron our a post workflow for a short film shooting 5D3 Magic Lantern RAW but run into problems exporting proxies from Davinci Resolve Lite.
I am trying to create 23.976 Apple ProRes Proxys.
I am following this tutorial. However when I make it to the DELIVER tab and create an export I continually end up with footage that is 59.95fps. Here is what I'm doing:
Shoot clips on 5DMKIII, ML RAW, 1920x1080, 24 ALL-I.
Copy RAW files to external HD. Create CinemaDNG from RAWs using RAW Magic Lite.
On to Davinci Resolve Lite; create a new project,making sure it is 23.976fps before importing media into the pool.
I import my footage into the media pool and encounter my first divergence from the tutorial; a prompt tells me that the "selected clip(s) have a different frame rate from the project settings." I chose "Don't Change" (though I have tried selecting change with no different results!)
Regardless I make a new timeline in the EDIT tab where I place my clips. I adjust the clip settings, move over to the DELIVERY tab and follow the tutorial as best I can.
I have attached screen shots of my settings. For whatever reason I always end up with a ProRes clip that is 59.976fps.
Help thanks!!
-Drew
Massimo Alberto Croce
Re: ML RAW Workflow - Problems Rendering Desired Frame Rate
on Jul 1, 2014 at 10:44:15 pm
what is the footage fps in the media pool, try to change the frame rate of DNG sequence there in the "clip attribute".
Video Editor, Colorist, Pro Tools Editor
massimoalberto.croce@gmail.com
Drew Angle
on Jul 2, 2014 at 1:53:18 pm
Thank you!
That was exactly the issue. Since it's just a sequence of stills Davinci was interpreting it at 59.97. I simply placed the "clip" into the media pool, right-clicked and selected the Clip info.
Wonder if there is a way to have Davinci default to 23.976fps for DNG sequences?
on Jul 2, 2014 at 10:39:56 pm
you're welcome! I honestly do not know if it is possible to set-up Davinci default to 23.976fps for DNG sequences, but you can select more than one sequence and modify at once.
