object passing in the front
COW Forums : DaVinci Resolve
Cesar Mendonca
on Jun 30, 2014 at 10:36:53 am
Hi guys,
I'm correcting a scene and a woman passes in the foreground and sweeps across my image.
How can I create a mask that will disable all other corrections while she passes?
cheers and thanx for the input
cesar
MEndonca
Sascha Haber
Re: object passing in the front
on Jun 30, 2014 at 12:59:21 pm
The easiest is to use a second track in which you copy your clip, delete all nodes, create an alpha output and then make one node in which you draw your shape.
That will overlay the ungraded foreground without tampering with all the rest.
It also gives you the freedom to grade her separately and play with the blend nodes of the second track
A slice of color...
Resolve 10.1.4 - Smoke 2015
Colorist / VFX / Aerial footage nerd
http://vimeo.com/saschahaber
Joseph Owens
on Jun 30, 2014 at 5:00:37 pm
[Sascha Haber] "The easiest is to use a second track in which you... &tc."
Or a tracked power window in the appropriate shape.
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
Cesar Mendonca
on Jul 1, 2014 at 2:44:21 pm
thanx guys,
I'll give it atry and see how it goes.
cheers
MEndonca
