PPro CS6 XML to Resolve
COW Forums : DaVinci Resolve
jim bachalo
on Jun 3, 2014 at 12:34:51 pm
Read this post over on the film bakery blog about a one way workflow using FCP and Resolve for finishing.
http://www.thefilmbakery.com/blog/one-way-trip-with-resolve-10
Was excited to see if I could get it to work using PremierePro CS6.
My sequence in PPro was standard, although I had 1 dynamically linked clip from After Effects.
The result of my export-import was that ALL my audio files failed to be imported , the dynamically linked After effects clip didn't make it, and many of my remaining clips were improperly scaled even though I clicked retain sizing info.
What a mess!
The error message I get is
The clip 'foo' failed to link because the media file'foo' is missing or has the wrong timecode extents.
Is this a wasted exercise for Premiere pro?
Is it impossible to properly import dynamically linked clips?
Will I have better luck using FCPX?
You should follow me on Twitter here. My latest work
