Colour Data not importing with XML
COW Forums : DaVinci Resolve
Kate Dolan
on May 18, 2014 at 5:05:35 pm
So I shot two people's Aerial Hoop showreels on my 7D the other day. Did an edit of each of the reels and then brought the first one into Da Vinci Resolve Lite to grade it. Then brought it back into FCP 7 via XML and all was perfect. Grade was there just as I had done it in Da Vinci.
Then I went to do the same with the 2nd person's reel however after grading when I import the graded XML back into FCP 7 there is no grade on it whatsoever, the footage is as it was when I exported it in the first place.
At a loss to how to fix the issue as it works perfectly fine with the 1st cut, and the settings are the same for both. Is there something I'm missing here?
Any help would be greatly appreciated.
Kate
