Resolve Lite - Is it possible to run on a portable PC?
COW Forums : DaVinci Resolve
Christopher Lowden
on May 13, 2014 at 5:26:10 pm
Hello
I would like to start learning Davinci Lite and I want to buy a portable PC for this. Can anyone recommend a cheap PC config so that I can learn the basics? I can happily work in SD or compressed HD as I will not be using it for production.
Many thanks
Margus Voll
Re: Resolve Lite - Is it possible to run on a portable PC?
on May 13, 2014 at 8:22:51 pm
look at the GPU's in laptops.
I have seen one DOP around here has Lite running in he's laptop.
Not sure what model but basically you should find one.
Margus
http://iconstudios.eu
https://vimeo.com/iconstudioseu/videos
DaVinci 10, OSX 10.8.5
MacPro 5.1 2x2,93 24GB
GUI 4000 / GPU GTX 780
DL 4K
Eizo Color
Scope Box
Full Ligthspace CMS
Glenn Sakatch
on May 14, 2014 at 1:55:32 pm
you need cuda acceleration for it to run. If you spec out a laptop, make sure of that. I have an HP Zseries laptop and it runs fine, but some of the models only have built in hp graphics, not nvidia, so beware. you also need 1920 x 1080 min. resolution. a 13 inch laptop won't work. You may find it cheaper to build a desktop and put an nvidia card in it. Check the resolve specs on their website. (there are different specs for windows vs Mac)
Glenn
Christopher Lowden
on May 14, 2014 at 5:36:39 pm
Thank you both for the advice. I did not see anything on portable PCs on the BM site but if I only need a decent CUDA validated card and a 1920 screen, I have plenty of choice.
Thanks again
Sascha Haber
on May 14, 2014 at 6:33:09 pm
I would go for an external Display anytime.
A slice of color...
Resolve 10.1.4 - Smoke 2015
Colorist / VFX / Aerial footage nerd
http://vimeo.com/saschahaber
