Bug with imx mxf files?
COW Forums : DaVinci Resolve
Andreas Knop
on May 2, 2014 at 2:51:26 pm
I'm using da vinci resolve 10 on windows 7.
On the Media-Tab I click some folder to import media.
Every time when the folder includes some sony-imx coded file with mxf-wrapper then da vinci searches and searches and...and finally also finds no other file codec (f.a. DNxHD).
Every time the folder owns no sony-imx codec then everything works fine.
Is this some strange bug or why doesn't resolve simply ignore not readable files and only show the readable ones?
Rohit Gupta
Re: Bug with imx mxf files?
on May 3, 2014 at 4:57:22 am
Are you able to post a sample clip which would show the problem?
Alternatively, send the clip to our support and ask them to forward to me.
Andreas Knop
on May 8, 2014 at 9:18:53 am
Thanks for your help.
unzip and look at following path:
Test TON PCM/Avid MediaFiles/MXF/1/TESTUFPCV01.5368A84A.0058D0.mxf
7456_testtonpcm.zip
