 | Eizo CG246 and Davinci Resolve
on Apr 19, 2014 at 9:26:43 am |
Hello everyone,
I'm using resolve with an Eizo CG246.
I seem to have to put "Range extension" ON on my Eizo (in REC709 mode) to have correct black when activating the "use normally scaled video level" monitoring setting in Resolve.
As I find it odd, I was wondering if I was doing something wrong?
ps: I'm feeding the Eizo via a Declink mini monitor with HDMI.
Thank you in advance
 | Re: Eizo CG246 and Davinci Resolve on Apr 22, 2014 at 9:33:10 am |
I feed mine from DL 4K.
Calibrated with LigthSpace CMS and uploaded the out directly to the monitor.
Seems to work as it should be. And of course you use video levels with range extension.
Margus
http://iconstudios.eu
https://vimeo.com/iconstudioseu/videos
DaVinci 10, OSX 10.8.5
MacPro 5.1 2x2,93 24GB
GUI 4000 / GPU GTX 780
DL 4K
Eizo Color
Scope Box
Full Ligthspace CMS
 | Re: Eizo CG246 and Davinci Resolve on May 18, 2014 at 6:19:21 am |
please help me.
I have Eizo 243W + Deck Link Mini monitor + Resolve
How can I connect from SDI or HDMI (DL mini) to Display port (Eizo). Please help me I need 10 bit signal. I think Eizo 243W DVI port is 8bit correct me if Im wrong.
Thanks in advance
