Automatically match master timeline with media pool
COW Forums : DaVinci Resolve
Eric Chase
on Apr 8, 2014 at 7:24:17 pm
(Not sure if this was covered, I'm using the latest DR10.1.3)
Remember Resolve always had the master timeline, that when you changed on shot, the rest of the shots from that media file was colored?
Before importing footage or a timeline, I clicked on "Automatically match master timeline with media pool" then imported my XML.
I got all my shots in, but when i color 1 shot, the others from that clip don't have the grade applied.
What am I missing?
Eric Johnson
Re: Automatically match master timeline with media pool
on Apr 8, 2014 at 7:50:36 pm
Pretty sure Resolve still defaults to "Local" grading, so you need to set you timelines to use "Remote" grading.
eric b johnson
online editor | colorist | workflow
http://vimeo.com/ebjohnson/colorreel
Eric Chase
on Apr 8, 2014 at 8:36:09 pm
If I uncheck "use local version for new clips in timeline" nothing changes. I still need to apply a grade to every edit.
Eric Johnson
on Apr 8, 2014 at 9:03:34 pm
If you right click the timeline, may need all clips selected, in the Color Page, there is an option to use Remote/Local grades.
The check mark you are referring to only effects NEW media in the project... not new grades.
eric b johnson
prathvish hegde
on Apr 9, 2014 at 6:25:54 am
hi Eric,
there is an option to copy remote grades to local which is helpful if you have graded the mastertimeline.
prathvish hegde
colorist
(DaVinci Resolve and 2Kplus)
http://www.youtube.com/playlist?list=PLRPJQ3fIEoojI3JMa4rHKb9gqq8VeIZ81
Paul Provost
on Apr 9, 2014 at 3:50:15 pm
I would uncheck use local grades when importing
Check Automatically match to master timeline
Check auto save every twenty or whatever for good measure
Save that as a user preset so it always does this
Start a new project and import XML
Color trace any grades over if needed
And the newest is 10.1.4
http://www.filmandtvcolor.com | colorist | Los Angeles, CA
Twitter: @4kfinish
Eric Chase
on Apr 11, 2014 at 12:53:16 am
Thanks, that worked!
Now that I have the timeline changing all at once, what would be the switch to make once clip to color separately from the rest of the takes?
Paul Provost
on Apr 11, 2014 at 1:14:14 am
right click on a clip thumbnail and chose make new version / remote
then download the brand new manual Feb 2014 from support page and read it
cover to cover
twice
Twitter: @4kfinish
Marc Wielage
on Apr 11, 2014 at 10:40:51 am
[Paul Provost] "then download the brand new manual Feb 2014 from support page and read it cover to cover... twice"
Very wise advice.
Juan Salvo
on Apr 11, 2014 at 1:03:34 pm
He doesn't call himself "the oracle" for nothing. ;)
http://JuanSalvo.com
http://theColourSpace.com
