New MacPro Big render issue. Be carefull
COW Forums : DaVinci Resolve
Robin Erard
on Mar 27, 2014 at 1:48:59 pm
Hello,
I spent 6 days testing my MacPro because I had an issue with render artifact.
Good news I'm not the only one : http://forum.blackmagicdesign.com/viewtopic.php?f=11&t=19703&p=123440#p1234...
That's a big thing, and it seems (according to Blackmagic to be a GPU problem.
Robin
réalisateur, scénariste, monteur, étalonneur
http://www.robinerard.ch
Ryan Holmes
Re: New MacPro Big render issue. Be carefull
on Mar 27, 2014 at 2:04:05 pm
I believe more specifically, it's an OpenCL problem. Adobe users are having the same artifacts when rendering from Premiere on the new Mac Pro. Adobe allows the user to pick the rendering engine at export (software, OpenCL, or CUDA), so some have gotten around the issue by using software only to render....not an option with Resolve.
Hopefully this bug gets squashed fast!
Ryan Holmes
http://www.ryanholmes.me
@CutColorPost
Robin Erard
on Mar 27, 2014 at 6:12:19 pm
Hello,
I managed to create 3 videos capture screen to show you the problem.
Tested on R3D files 4K from Red One. Resolve 10.1.3.
Everything is downloadable with this wetransfer link :
http://we.tl/1Vlqixbq1P
You will see in Demo1 and 2 that the problem appears in Color page, Edit
Page and Render page and Render Result. In Demo 3, you will see the problem
in Color page but not in the render. I didn't change anything between these Demo
1,2,3. The problem is that's not constant. Sometimes it appends sometimes
not.
Here is an other example of the problem that could show a GPU problem : http://we.tl/feP7gEEHG8
Rohit Gupta
on Mar 27, 2014 at 11:10:13 pm
Hi Robin,
You should consider a warranty replacement unit and see if it helps. It could be a software issue, but I get the feeling it's a bad GPU or VRAM.
Regards,
Rohit
EricBowen
on Mar 28, 2014 at 5:09:38 pm
CUDA is Nvidia only. Open CL is the only option with those AMD cards.
Eric-ADK
Tech Manager
support@adkvideoediting.com
