Tangent Wave crashes with Resolve 10
COW Forums : DaVinci Resolve
Kathleen Thomson
on Mar 25, 2014 at 12:12:11 am
I just purchased a Wave panel and it crashes when ever I push one of the buttons,or turn a knob, the tracker balls and wheels work fine, and I can at least control the transport using the mac key board. I have a new 27"(late 2013) iMac, OS X ver 10.9.2 and I downloaded the most current Wave firmware 1.1.2. I went through the posts from back in December and none of them worked including changing the Preferences I/O and GPU to Open CL as Dwayne suggested.
Thanks in advance for any help.
Kathy
Robert Ruffo
Re: Tangent Wave crashes with Resolve 10
on Mar 25, 2014 at 12:40:22 am
Try another USB port, or try another USB cable. Does your Wave work with other software like Speedgrade?
Kathleen Thomson
on Mar 25, 2014 at 5:16:01 am
Thanks Robert, I changed the usb port, still crashes, need to find another cable to rule that out, do I use Speedgrade instead of Resolve with the iMac and the Wave? Haven't heard of Speedgrade before this.
Peter Chamberlain
on Mar 25, 2014 at 1:41:44 pm
Did you try the driver tangent offer to fix the maverick related bug?
http://www.tangentwave.co.uk/support.asp
Kathleen Thomson
on Mar 25, 2014 at 2:30:17 pm
Hi Peter, when I first got the panel I went to the site and downloaded 1_12wuf which had the note about the Maverick fix. That's the version I currently have. Am I missing anything else from the site?
Kathleen Thomson
on Mar 25, 2014 at 11:27:31 pm
I went back and reloaded the 1.9 firmware then reloaded the 1_2wuf and it finally fixed it.
Thanks all
