Tool to search for black frames?
COW Forums : DaVinci Resolve
Michael Neumann
on Mar 24, 2014 at 2:13:57 pm
Hey there,
my Resolve outputs black frames from time to time into my exported DNxHD files. Is there a way, a plugin maybe, that I can have premiere run through the file and alert me if there is a black frame?
Any help appreciated!
Eric Johnson
Re: Tool to search for black frames?
on Mar 24, 2014 at 5:19:01 pm
Not sure if it works with DNxHD, but I', pretty sure Digital Rebellion has an app in one of it's bundles that does something to that effect.
eric b johnson
online editor | colorist | workflow
http://vimeo.com/ebjohnson/colorreel
Jon Chappell
on Mar 24, 2014 at 7:00:27 pm
Yes, it's called Video Check and it's in Pro Media Tools:
http://www.digitalrebellion.com/promedia
But it uses AV Foundation so no third-party codecs I'm afraid.
My software:
Pro Maintenance Tools - Tools to keep Final Cut Studio, Final Cut Pro X, Avid Media Composer and Adobe Premiere Pro running smoothly and fix problems when they arise
Pro Media Tools - Edit QuickTime chapters and metdata, detect gamma shifts, edit markers, watch renders and more
More tools...
Michael Neumann
on Mar 24, 2014 at 9:41:48 pm
I tried "Video Check" and it worked well with an .mp4 and detected a flashing frame. The same file converted to DNxHD 4:4:4 (my main format) didn't show up with any negative results although I could clearly see the flashing frame when scrubbing through the footage.
Also I would like the program to check about 500 files for export failures, which Video Check is not capable of (no batch).
Any other ideas?
I thought about running all the files through scene detection, which should work nicely but is also a lot of work.
Jon Chappell
on Mar 24, 2014 at 10:30:39 pm
As I mentioned, it doesn't support DNxHD.
My software:
More tools...
