DaVinci Lite
COW Forums : DaVinci Resolve
Grzegorz Kwiatkowski
DaVinci Lite
on Mar 22, 2014 at 7:59:28 am
Can somebody tell me what are the main limitations of the Lite version? Can I use it to work with HD footage and output HD? I heard it limited to SD. Is it true?
thanks
MichaelMaier
Re: DaVinci Lite
on Mar 22, 2014 at 9:47:49 am
Main limitations are:
Only up to HD
Only one GPU
No noise reduction
No remote grade.
Peter Chamberlain
Re: DaVinci Lite
on Mar 22, 2014 at 11:26:51 am
Not quite correct.
DaVinc Resolve Lite is limited to
UHD timeline and renders
1 image processing GPU ( except for the new MacPro where we use both )
1 red rocket
And
No remote grading
No shared project database
No stereoscopic 3D timelines
No motion effects or spatial or temporal NR
MichaelMaier
Re: DaVinci Lite
on Mar 22, 2014 at 11:31:02 pm
Good to have an official reply Peter.
Now could you reply to this question: http://forums.creativecow.net/readpost/277/29021 ?
Re: DaVinci Lite
on Mar 24, 2014 at 4:01:25 am
thanks
Eric Sternberger
Re: DaVinci Lite
on Mar 27, 2014 at 10:33:46 am
Hi Peter,
thanks for your input. But could you elaborate a little bit more, what exactly image processing in that context means?
Do you mean: Rendering is done by dual GPUs - but only on the new macpro?
or do you mean: On GPU is taking care of effects, the other is running GUI on the new MacPro?
If the latter is the case: Wasn´t that true for all dual GPU-Machines?
Kind Regards!
