DaVinci Resolve 10.1.3 released
COW Forums : DaVinci Resolve
Peter Chamberlain
on Mar 19, 2014 at 6:02:08 am
Hello all, we are pleased to announce the release of DaVinci Resolve 10.1.3 for Mac, Windows and Linux OS. Existing customers can download the no charge release from our support web site. There is also a Resolve Lite for Mac and Windows version for download.
This release includes
• Color page GUI performance improvement when using Mavericks
• Update to RED SDK 4.6, which includes support for Dragon OLPF and Rocket-X when using RED ONE clips
• GPU debayer Preferences option for RED RAW clips
• Support for 'Content Kind' selected in the DCP composition name dialog
• Stereo Decision List import for ColorTrace
There is no database update required so the upgrade should be quick and easy.
Peter
Robin Erard
Re: DaVinci Resolve 10.1.3 released
on Mar 19, 2014 at 6:44:55 am
Hello,
Great news, does it mean that Davinci will be able to play 5K R3D files fulldebayer realtime (like in the preview version of Adobe Premier) ?
Robin
réalisateur, scénariste, monteur, étalonneur
http://www.robinerard.ch
Juan Salvo
on Mar 19, 2014 at 3:57:42 pm
With the right hardware. Most certainly.
http://JuanSalvo.com
http://theColourSpace.com
Toby Tomkins
on Mar 19, 2014 at 9:16:39 am
Amazing! Is the GPU debayer multi-GPU enabled?
Rohit Gupta
on Mar 19, 2014 at 12:07:06 pm
Yes of course!
Harris Charalambous
on Mar 19, 2014 at 1:43:42 pm
Anxious to try this out! 10.1.3 seems to install but crashes on launch every time. Any thoughts why this might be? I'm on Mavericks 10.9.2 on a nMP.
Chris Hall
on Mar 19, 2014 at 6:33:39 pm
Can anyone comment on the order of operations used now for R3D debayer if both are used at the same time w/each other. For example if I were to use a Red Rocket and Two Titans in a cubix and enabled both for R3D debayer, would they work in tandem or would the rocket override the two titans? Anyone tried this? (I'm thinking I've got a red rocket that's pretty much useless now…alas the day was coming I suppose)
Chris Hall
Colorist - Prehistoric Digital
Santa Monica, CA
Juan Salvo
on Mar 19, 2014 at 8:42:48 pm
One or the other. not both.
Laco Gaal
on Mar 20, 2014 at 1:38:15 pm
what is a better setup currently for generating DNX36 dailies (quarter-res)? A RR-X, or a multi-GPU setup?
thanks
Paul Provost
on Mar 19, 2014 at 2:38:27 pm
Awesome. Mac Pro 12 core 2.4 one titan in cubix. 4k r3d full premium realtime 23.98 with grade and blur.
5k only 17fps.
With two titans in cubix 5k still only 17fps.
OS 10.8.5
http://www.filmandtvcolor.com | colorist | Los Angeles, CA
Twitter: @4kfinish
Juan Salvo
on Mar 19, 2014 at 3:59:45 pm
You need to take a holistic approach. In this case the CPU is the bottleneck. You need both a fast CPU and highend GPU. But if you can get a good combo (lots of CPU cores help) the results are pretty jaw dropping. :)
Toby Tomkins
on Mar 19, 2014 at 9:13:38 pm
Paul what is your timeline resolution with those results?
prathvish hegde
on Mar 22, 2014 at 6:48:58 am
2 titans
5k r3d full premium - 17fps
5k r3d half - 17fps
redrocket
5k r3d half - 17fps
while there isnt much difference between the redrocket and titan but i think resolve is not using the second titan for debayeringing r3d also half resolution and full resolution premium are playedback at the same speed :( .
anyways nice fitst step .
setup specs:
supermicro system with 2 titans(gpu),redrocket,decklink extreme 3d,hba,quadro 4000(gui),controlsurface and dolby prm4200,omnitek.
prathvish hegde
colorist
(DaVinci Resolve and 2Kplus)
http://www.youtube.com/playlist?list=PLRPJQ3fIEoojI3JMa4rHKb9gqq8VeIZ81
Chris Kenny
on Mar 22, 2014 at 1:15:30 pm
[prathvish hegde] "while there isnt much difference between the redrocket and titan but i think resolve is not using the second titan for debayeringing r3d also half resolution and full resolution premium are playedback at the same speed :( "
Seeing the same thing on a 12c/D700 Mac Pro — Half Res Premium with 5K Epic footage seems to be basically the same speed as full-res (similar speeds to what you're seeing). I wonder what's up there.
Half Res Good is silky smooth now though, and full-res decodes are actually a little faster than what we got from the Rocket over Thunderbolt, so the Rocket is officially getting retired from our grading suite. I suppose it will still have its place for on-set transcoding (hooked up to a MacBook Pro). Although if buying a system for on-set transcoding today we'd probably just figure out how to pack up a Mac Pro now that it's so tiny, and forget the Rocket.
Digital Workflow/Colorist, Nice Dissolve.
You should follow me on Twitter here. Or read our blog.
Rohit Gupta
on Mar 22, 2014 at 3:41:06 pm
We're getting 5K full-res in RT on the 12-core/d700.
Chris Kenny
on Mar 23, 2014 at 12:01:54 am
[Rohit Gupta] "We're getting 5K full-res in RT on the 12-core/d700."
Is that with full frame footage or is that 5K widescreen? Mine seems to settle down at ~18-20 fps with full res full frame 5K material. Same in 'half res premium' mode. (I copied a couple of clips to the internal SSD to rule our storage bottlenecks.)
Rohit Gupta
on Mar 24, 2014 at 5:36:57 am
It's a 5120x2560 clip.
Anish Prithviraj
on Mar 24, 2014 at 5:06:23 am
Hi Prathvish/Chris,
Please make sure that you disable "Use Red Rocket if available". If that is enabled and a rocket is available, it is using the rocket instead of GPU (even if GPU for Red Debayer is enabled).
Anish
Chris Kenny
on Mar 24, 2014 at 5:11:25 am
[Anish Prithviraj] "Hi Prathvish/Chris,
Please make sure that you disable "Use Red Rocket if available". If that is enabled and a rocket is available, it is using the rocket instead of GPU (even if GPU for Red Debayer is enabled). "
Unchecked here (and the Thunderbolt Rocket is disconnected). I'm curious if something might be wrong here and I should be seeing better performance.
prathvish hegde
on Mar 24, 2014 at 7:36:57 am
hi anish,
the tests are with redrocket disabled. 2 titans no big difference.
prathvish hegde
colorist
Rohit Gupta
on Mar 24, 2014 at 7:57:33 am
Prathvish, what is your CPU model? Please provide the exact model so we can get the number of cores and clock-speed, etc.
prathvish hegde
on Mar 25, 2014 at 8:43:01 am
hi rohit,
it says intel(r) xeon(r) cpu X5650 @ 2.67ghz on my linux device manager.
prathvish hegde
colorist
Jonathon Lee
on Mar 20, 2014 at 2:44:41 pm
Has anyone tried this on a Windows resolve or macs only so far?
Robert Ruffo
on Mar 20, 2014 at 9:55:56 pm
Anyone take a close/careful look at quality differences (if any) between GPU and CPU debayer? WIth Rocket quality was much lower, and I am hoping there is no difference with GPU
Robert Ruffo
on Mar 20, 2014 at 11:50:23 pm
Instant crahs with anything that has Red files in it.
4GIG VRAM gtx 680 on Mac Pro 12 core - granted I tried it while a screen was hooked up to the compute card.
Also gave me that weird "Red decoders not same number…" error
Perry Trest
on Mar 24, 2014 at 8:18:59 pm
Where is the setting to engage GPU debayering of RED footage?
I can't locate it in the manual and have obviously overlooked it in the settings panel.
Perry Trest
POSTDIGITAL, Inc.
Davinci Resolve 10 Licensed
MacPro 12core 2.66Ghz
20GB RAM
Slot 1 = ATI 5770
Slot 2 = Quadro 4000
Slot 3 = DeckLink SDI
Slot 4 = Nitris DX HIC
Internal 6TB soft RAID-0
Euphonix Artist Color
Flanders Scientific CM170W
Davinci Resolve 10 Lite
iMac 27" 2.7GHz Quadcore i5
20GB RAM
Blackmagic Mini Monitor
Paul Provost
on Mar 24, 2014 at 8:23:07 pm
ver 10.1.3
not in manual yet
set in preferences
Twitter: @4kfinish
Dmitry Kitsov
on Mar 28, 2014 at 7:41:06 pm
Getting full debayer with no frame drops on windows 8.1. Running three titans plus GUI
Paul Provost
on Mar 28, 2014 at 7:49:44 pm
Dmitry,
Debayer of what? what frame size? aspect ratio? compression ratio? frame rate?
what CPU?
Twitter: @4kfinish
Mario Moskon Sarunic
on Mar 28, 2014 at 10:11:41 am
GPU debayering of RED files is CUDA only?
We are testing new Mac Pro with D300 cards and and it looks like gpu debayering is not working on Ati.
Juan Salvo
on Mar 28, 2014 at 6:40:50 pm
[Mario Moskon Sarunic] "GPU debayering of RED files is CUDA only?"
Nope, both.
[Mario Moskon Sarunic] "We are testing new Mac Pro with D300 cards and and it looks like gpu debayering is not working on Ati."
That's a pretty weak GPU and I'm assuming you have a 4-core or maybe 6-core model... that's not helping either.
