Calibrating JVC DT-V24G1 24"
COW Forums : DaVinci Resolve
Frans Suijs
on Mar 14, 2014 at 7:48:34 am
I'm trying to calibrate a JVC DT-V24G1 24" monitor with the JVC calibration software. Can anyone advise me on the settings I have to use? Target gamma, luminance & white balance.
Thanks in advance!!
Frans
Toby Tomkins
Re: Calibrating JVC DT-V24G1 24"
on Mar 14, 2014 at 9:06:03 am
For broadcast rec709 work grading in a dim environment use a target gamma of 2.4, target luminance of 35 ftl / 120 cdm2 and a white temperature of 6500K
Frans Suijs
on Mar 14, 2014 at 11:14:39 am
Thanks Toby,
That's all I needed to know!! I don't grade in a dim environment in which it is totally dark. Will the gamma/luminance and white temp will be suitable then?
Best regards,
Frans
Mario Moskon Sarunic
on Mar 14, 2014 at 9:52:29 am
Frans can you explain me how to calibrate DT-V24G1? I have same model and I would like to calibrate it but I dont know how to do it and what do I need :/
Frans Suijs
on Mar 14, 2014 at 11:18:15 am
Hi Mario,
You'll need the JVC calibration software: http://www.jvc-monitor-calibration.com It's only for PC.
Then you need the Xrite i1, the OEM version, available at JVC. You need a serial port or USB-to-Serial adaptor for monitor communication and a HDMI to DVI-D cable for the video signal.
In the software you can use the settings Toby mentioned.
Best regards,
Frans
on Mar 14, 2014 at 11:20:54 am
Thank you!
