compare different grades
COW Forums : DaVinci Resolve
Rick van den Berg
on Mar 3, 2014 at 8:09:09 pm
is it possible to create more grades at the same shot to quickly switch and compare/tweak?
for example, in apple color you can just click something like ''add new grade''. Im familiar with the ''grab still'' function but when you got a production with a few hundred shots (wich i got now), and you want to create 4 versions of each shot, i guess it will be a mess. it would be perfect if you could just press '1' for grade 1, and '2'for grade 2 and so on.
any tips/suggestions?
Robbie Carman
Re: compare different grades
on Mar 3, 2014 at 11:19:31 pm
yes, versions allow you do exactly what you're asking. You have unlimited versions in resolve, you can name them etc. There are shortcuts for quickly flipping back and forth and depending what panel (if any) you're using there are version buttons for moving between the different grades.
All of this BTW clearly outlined and defined in the user manual.
Robbie Carman
Colorist and Author
My Books
Online Training
Twitter
Blog
Mixing Light Powered By The Tao Of Color
Rick van den Berg
on Mar 4, 2014 at 8:54:45 am
thank you very much! that was indeed exactly what i was looking for.
Marc Wielage
on Mar 4, 2014 at 8:30:23 am
Versions: pp. 639-642.
I believe the shortcut for cycling through versions is option-P, but there's a dedicated button for it on the full daVinci panels.
Rick van den Berg
on Mar 4, 2014 at 2:48:06 pm
thats what the website says too, but for some reason for me it's command + y (new) / b (previous) / n (next). thanks anyway
