Resolve 10.1 Keyframing Single Node Power Window?
COW Forums : DaVinci Resolve
Matthew Rogers
on Feb 28, 2014 at 4:52:12 pm
Hey guys, so I am having an issue figuring out how to keyframe a power window on a single node and not have it add key frames for all my other nodes. I am used to After Effects/FCP/etc. style of keyframing where you can select that layer/node/etc and keyframe just it. However, I can not figure out how to do it and can't find a tutorial on how to.
Is there a tutorial I haven't found or an easy way to explain how I can keyframe a power window on one node without it messing up a key framed power window on another node? Is this even possible?
Thanks.
Joseph Owens
Re: Resolve 10.1 Keyframing Single Node Power Window?
on Feb 28, 2014 at 8:30:01 pm
[Matthew Rogers] "how I can keyframe a power window on one node without it messing up a key framed power window on another node? Is this even possible?"
Yes it is... there is a disclosure arrow associated with each node in the lower right hand side keyframe window.
Right-Click will bring up a dialogue that enables you to add keyframes on the parameter you desire. You can lift, drag, delete them... static, dynamic, change state...
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
Margus Voll
on Mar 1, 2014 at 9:38:20 am
I think you have some confusion with terminology here?
Node is more like layer in AE and Power window is like effect or mask in AE.
So you can only animate one node or its properties (windows) at a time.
Special case would be if you have little A turned on for all the nodes you have
but that is not the case most likely.
Does this make more sense like this ?
Margus
http://iconstudios.eu
https://vimeo.com/iconstudioseu/videos
DaVinci 10, OSX 10.8.5
MacPro 5.1 2x2,93 24GB
GUI 4000 / GPU GTX 780
DL 4K
Eizo Color
Scope Box
Full Ligthspace CMS
Andy Winter
on Mar 1, 2014 at 2:16:55 pm
there is a drop-down box at the keyframe editor: ALL/COLOR_/PTZR. if you select color,
the keyframes will only affect that node.
Matthew Rogers
on Mar 1, 2014 at 7:52:22 pm
Thanks Andy, that's exactly what I was looking for. It doesn't make any sense why it labeled like that, but it works for me and that's all that matters.
