Easiest way to raise and clip black levels?
COW Forums : DaVinci Resolve
Nat Jencks
on Feb 8, 2014 at 12:01:29 am
There's got to be a way to do this more easily… for a while I have been using a little trick where i put three nodes, one to clip blacks, another with a slight soft clip on black which makes blacks irretrievable, and then another which pulls blacks up.
Anyone have a tip on an easier way (without 3 nodes) to clip and lift blacks?
thanks
-Nat
Juan Salvo
Re: Easiest way to raise and clip black levels?
on Feb 8, 2014 at 2:35:09 am
Just us the soft clips.
http://JuanSalvo.com
http://theColourSpace.com
Nat Jencks
on Feb 8, 2014 at 2:57:23 am
Should have specified, I want to lift/clamp blacks more than is possible by simply using the traditional soft clip.
I'm working with various 8mm and 16mm footage and frequently want to match the heavily clamped / lifted and tinted black levels of various Lo-fi transfers. I guess the 3 node method is it, just wishful thinking. I guess I could achieve this with curves but not ideal.
I'd love to be able to leave the age exactly as is but raise / clip the blacks up to high levels...
Juan Salvo
on Feb 8, 2014 at 4:42:22 am
You can get them pretty high by lifting the clip... there are two controls on the soft clips... clipping and softness. Raise the clip level and you can get a rather high amount of lift.
Nat Jencks
on Feb 8, 2014 at 10:24:59 pm
Understood, I'm matching some 8mm film transfers with quite extreme looks and need to really pull the blacks up. Thanks for the feedback, I'll keep on doing what I've been doing!
best-
-Nat
Joakim Ziegler
on Feb 13, 2014 at 3:21:25 am
Use curves.
Joakim Ziegler - Postproduction Supervisor
Nat Jencks
on Feb 13, 2014 at 3:47:10 pm
Yes indeed, curves work decently for this, but it takes a little patience to create a flat toe on the curve and ride it up and down to elevate or lower the floor…
What I would really like is just soft clip but with more range to allow for more stylized looks (matching old vintage poor quality transfers).
Honestly I'll just keep using my 3 node approach w/ a soft clip to clip and pull values out of floating point.
thanks everyone for the great suggestions.
best-
-Nat
