Apply Camera Raw Settings to all clips in group?
COW Forums : DaVinci Resolve
Francois Driessen
on Feb 4, 2014 at 2:40:12 am
Am I missing something..? But Camera Raw Master Settings does not ripple through groups in V10.1.1
Is there a way that I can apply the same Camera Raw setting throughout my project to all the clips before I start grading? (Not using Project LUT)
I need to decode using Clip, have BMD film Color space selected and have Highlight Recovery switched on. + have a second node with the BMD Film to 709 LUT.
The Second node ripples through the group, but it seems like I have to manually apply the Raw Master Settings clip-by-clip from another Node Graph...
Any ideas out there that could save me the 6 x1000 repetitive mouse-clicks... ?
Francois
FireTrigger Inc.
http://firetrigger.com
eddie smith
Re: Apply Camera Raw Settings to all clips in group?
on Feb 27, 2016 at 2:19:28 am
I would love to know the solution to this as well. It's driving me nuts!
Francois Driessen
on Feb 27, 2016 at 1:01:59 pm
Are you still on Resolve10 (when this post was originally made) or is the same issue still unaddressed in V12?
Francois
FireTrigger Inc.
Rohit Gupta
on Feb 28, 2016 at 2:27:25 am
Before you make any changes select all the clips in the thumbnail timeline in the Color page. After you change he settings, there is a button on bottom left of the palette which lets you apply the changes to all the clips.
Francois Driessen
on Mar 31, 2016 at 6:28:13 pm
Hi, R
I've tried to apply it as described with no luck. It defaults back the Project settings for handling raw. I need to use BMC Film colour space and that is not selectable from project settings as far as I can tell. Have you tested it with any other section than Decode Using Project ?
Any other advice out there?
-F
Francois
FireTrigger Inc.
Francois Driessen
on Mar 31, 2016 at 6:40:18 pm
OK - Think I figured it out.
NOTE: You cannot paste the grade info for Raw decoding from a still to the multiple clips selected. You have to paste it directly from a clip on the timeline. Raw decode settings seems to not be recorded in grabbing a Still.
Francois
FireTrigger Inc.
