Has anyone been able to use high res sources (4K 5K 6K) with new noise reduction without GPU RAM warning?
COW Forums : DaVinci Resolve
Robert Ruffo
on Feb 1, 2014 at 12:19:17 am
If you have been able, how much GPU RAM do you have?
Does it look at total GPU RAM, or just the amount in the first compute card?
Does using the same card for compute and GUI make a big RAM difference?
Timeline resolution does not seem to make much of a difference - just source resolution.
Paul Provost
Re: Has anyone been able to use high res sources (4K 5K 6K) with new noise reduction without GPU RAM warning?
on Feb 1, 2014 at 5:51:52 pm
Titan works with epic
http://www.4Kfinish.com | owner-colorist | Los Angeles, CA
http://www.facebook.com/4kFinish
Twitter 4kfinish
Juan Salvo
on Feb 1, 2014 at 9:17:23 pm
Second titan.
http://JuanSalvo.com
http://theColourSpace.com
Paul Provost
on Feb 1, 2014 at 9:49:01 pm
And they seem to be discontinued - out of stock everywhere. Well have to wait til titan black ships...
Twitter 4kfinish
Robert Ruffo
on Feb 1, 2014 at 10:08:22 pm
How much GPU RAM does your Titan have? I could be mistaken but I thought it came in several RAM amount variants.
Also:
- Are you able to use a Titan safely in a Mac Pro?
- Are you able to set search area up to 2 frames (over default 1)
- Have you tried Dragon footage? (6K)
- Does the Titan work well with any RAM-instensive OFX plugins you might have tried?
Thanks for your replies! Much appreciated!
Juan Salvo
on Feb 1, 2014 at 11:28:57 pm
Titans come with 6GB. If you want to be safe go with the K6000 which has 12GB. As far as inside the MacPro... doubtful without extra power. I use em in a Cubix.
Have tried with dragon. Works there too.
Robert Ruffo
on Feb 12, 2014 at 5:21:34 am
Thanks Juan! And thanks everyone!
As for external power just for the cards, anyone have a good solution?
Jesse Glucksman
on Feb 18, 2014 at 5:16:23 am
I got a Corsair for my GTX 780, and that's been working well once I figured out how to make it do it's thing (the saga and solution are found here: http://forums.creativecow.net/readpost/277/28464, with repeated gratitude to Clark Bierbaum). I have the TX650M, which is a tad overkill for just one GPU, but at only $100 it's a hefty bit of peace of mind. If you're looking to power more than one, you may want to research further to see if this one will suit your needs, or if another is better for you.
The rest of you--what's the word on the Tesla? I just learned they existed.
