DaVinci Resolve 10.1 released
COW Forums : DaVinci Resolve
Rohit Gupta
on Jan 17, 2014 at 6:14:22 am
Hello, we are pleased to announce the release of DaVinci Resolve 10.1 for Mac, Windows and Linux on the BMD web support site.
This no charge upgrade for existing customers includes rich text title support, a take selector to preview and align multiple takes and support for FCPX v10.1 XML 1.3. There are many more features detailed in the read me.
For full software license customers this release also includes stereoscopic 3D support with media pool syncing of the eyes and also stereoscopic 3D editing.
DaVinci Resolve Lite 10.1 for Mac and Windows is also available for download at the BMD web support site.
As a database upgrade is required for this release please backup your database or active projects prior to upgrading.
Bill Ravens
Re: DaVinci Resolve 10.1 released
on Jan 17, 2014 at 2:01:28 pm
The following two notes are provided in the v10.1 README:
• Support for rectangle patch size for monitor calibration
• Added monitor calibration support using xxx yyy
The User Manual is still dated October 2013. Is there a calibration procedure defined for the other 3rd party calibration software anywhere?
Juan Salvo
on Jan 17, 2014 at 2:18:58 pm
I think xxx yyy is Spectracal Calman.
http://JuanSalvo.com
http://theColourSpace.com
Bill Ravens
on Jan 17, 2014 at 4:15:51 pm
Juan....
You're right. but the last time I posted that name, my post was blocked. So, I used the generic name xxx yyy so my post wouldn't be blocked.:)
Juan Salvo
on Jan 17, 2014 at 5:12:09 pm
Ah, gotcha. So to answer your question... I think you'd need to contact the calibration software vendor for those directions. Resolve is just behaving as a pattern generator in that scenario.
Margus Voll
on Jan 17, 2014 at 11:19:48 pm
LS has good information on that in their forum.
can not say about yyy zzz.
Margus
http://iconstudios.eu
https://vimeo.com/iconstudioseu/videos
DaVinci 10, OSX 10.8.5
MacPro 5.1 2x2,93 24GB
GUI 4000 / GPU GTX 780
DL 4K
Eizo Color
Scope Box
Bill Ravens
on Jan 18, 2014 at 1:45:24 pm
Discovered that xxx yyy is still implementing compatibility with Resolve. Software updates and workflow info will be released at a later date.
Marc Wielage
on Jan 18, 2014 at 1:32:10 am
[Bill Ravens] "The User Manual is still dated October 2013. Is there a calibration procedure defined for the other 3rd party calibration software anywhere?"
The Resolve manual I see up on the support site as of today is dated November 7, 2013. But it's true that there's no v10.1 updated manual yet.
Michael Sanders
on Jan 17, 2014 at 9:35:31 pm
Where's the best place to report the few bugs I've found?
Michael Sanders
London Based DP/Editor
prathvish hegde
on Jan 18, 2014 at 1:55:17 pm
dont update if you have ongoing projects as i found that old projects are not opening after updating and after few times login and logout(resolve closes while opening the projects).
prathvish hegde
colorist
(DaVinci Resolve and 2Kplus)
http://www.youtube.com/playlist?list=PLRPJQ3fIEoojI3JMa4rHKb9gqq8VeIZ81
Andrew Shtern
on Jan 21, 2014 at 10:03:13 am
Why are you messing with keyboard shortcuts again and again?
Map keyboard to Resolve 8 - doesn't working. It's now mapping to Resolve 9 shortcuts (kind of). In this mapping Append a Node (Alt-N) shortcut doesn't working.
Everything was fine in 10.0.2, and yet somebody still wants to play with key mappings. And again, it is not Resolve 8 shortcuts.
C'mon, guys, we are trying to work here, please stop making our life harder than it already is. Better concentrate on something useful, like working cache, or custom clip directory names when rendering separate clips, or something else, that is really necessary. And if you want to experiment - please, do it with Lite version.
Thanks for comprehension.
Andrew Shtern
Editor/Colorist
The Coffeepost @Kiev, UA
Marc Wielage
on Jan 21, 2014 at 10:34:31 am
[Andrew Shtern] "Map keyboard to Resolve 8 - doesn't working. It's now mapping to Resolve 9 shortcuts (kind of). In this mapping Append a Node (Alt-N) shortcut doesn't working."
Do what I do and make a little cheat sheet and hang it on the side of your monitor. In a couple of weeks, you'll figure out the new shortcuts. It's not rocket science.
The other thing you could do is use a shortcut program like QuicKeys to remap the shortcuts yourself. That's kind of a kludge, but it would work.
Let's just hope they don't change them again in Resolve 11...
Nedeem Al-Astrabadi
on Feb 11, 2014 at 1:29:11 pm
They shouldn't be changing keyboard shortcuts under a legacy option though, it's a bizarre decision.
http://www.nedeem.com
Francois Driessen
on Jan 22, 2014 at 8:56:54 pm
UPDATE WITH CAUTION!
Working with BMCC DNG - My playback framerate dropped to 5fps vs the 39 I could get on my system before. Reverted back to 10.0.2 All back to normal now.
System: MacPro 3.1 8core 2.6
MacOS 10.9
Quadro 4000 GUI
GTX680 CUDA
Anyone else out there with the same issue?
Francois
FireTrigger Inc.
http://firetrigger.com
Andrew Shtern
on Jan 23, 2014 at 8:19:53 am
Yeah, i've had similar issue with general performance. Most things are significantly slower, like working with power windows for example (when resizing or moving window it's stuttering). This version even start about twice longer comparing to 10.0.2.
I'm on MacPro 2012 with 56Gb RAM and Quadro 4000. Rolling back to 10.0.2.
Andrew Shtern
Editor/Colorist
Margus Voll
on Jan 23, 2014 at 8:33:33 am
Q4000 is by default not wiry powerful ?
Margus
DL 4K
Eizo Color
Scope Box
Full Ligthspace CMS
Andrew Shtern
on Jan 23, 2014 at 1:20:49 pm
Yeah, but that's not an issue, since 10.0.2 is working way faster, than 10.1
Andrew Shtern
Editor/Colorist
Francois Driessen
on Jan 23, 2014 at 3:03:07 pm
The first few runs with Resolve was fine after the update. But then after opening & closing Resolve a few times it seriously halted. Similar to an earlier post made by another user above.
Francois
FireTrigger Inc.
