IR Removal In Post
COW Forums : DaVinci Resolve
Kyle Lavore
IR Removal In Post
on Dec 10, 2013 at 4:31:45 pm
This is probably a lost cause that will require a re-shoot, but I'm wondering if there is a way to remove IR Pollution in resolve. We shot on the BMCC (in RAW) using a 1.2 ND filter which caused the blacks to become reddish. Is there a known process to balance the blacks out?
Christian Betong
Re: IR Removal In Post
on Dec 10, 2013 at 9:41:54 pm
I use couple of techniques
Custom curves: pull down on bottom of the red channel.
Hue vs sat: pull down on the magenta a bit (IR usually pushes magenta a lot)
Hue vs hue. Pull magenta up a little bit pushing it towards blue (this breaks the picture fast so pull gently)
Hope to hear about other techniques as well
© 2018 All Rights Reserved
