10.0.2 messed up monitor configuration
COW Forums : DaVinci Resolve
Oliver Peters
on Dec 8, 2013 at 7:34:55 pm
I use dual 20" Apple Cinemas for my system UI. Their native resolution is 1680 x 1050. With Resolve 10.0 the UI fit within one monitor. With the 10.0.2 update it no longer fits and cannot be adjusted in width to fit. I have to slide the UI to the left into the overlap between the two screens otherwise the UI is lost on the right side. This worked correctly with 8, 9 and 10. Now it is messed up. If there is a new preference setting, I can't find it. Ideas?
Mac OS X Mavericks on a Mac Pro. ATI 5870 card.
- Oliver
Orlando, FL
http://www.oliverpeters.com
Oliver Peters
Re: 10.0.2 messed up monitor configuration
on Dec 8, 2013 at 8:36:08 pm
Problem fixed. Click on “show window frame” and click the Mac UI “+” icon button in the upper left of the frame and it resizes correctly.
- Oliver
Orlando, FL
andrew smith
on Dec 8, 2013 at 11:14:21 pm
Where exactly are these options you are saying to click - can you be clearer?
thanks
Oliver Peters
on Dec 9, 2013 at 12:15:14 am
Under the Resolve View menu, enable "Show Window Frame". This gives you a Mac UI frame across the top of the Resolve interface. In the upper left corner of that frame, you have the standard 3 button icons from the Mac OS. The right-most button is the + button. Click this to resize the frame to fit the display. I do notice that Resolve doesn't appear to remember this state, so you may have to do it each time you open Resolve.
- Oliver
Orlando, FL
