Unable to Select Node, Greyed out Box in Resolve 9.
COW Forums : DaVinci Resolve
Nina Frost
on Dec 3, 2013 at 8:45:44 am
Hi All,
I am new at this, so please be patient with me.
I shot some footage on 5D mark 3. In premiere pro CS6, after laying a sequence timeline, I exported an XML sequence.
In resolve 9, I imported the xml sequence. I opened the tab colour and started to do basic level balancing. I am able to preview the first node. BUT, here in the node window, I can't seem to select the node. I can move it, but when i double click on it, left lick, middle click, the node does not appear highlighted. I can move the node and the lines, but it refuses to highlight(no yellow outline box).
I then tried creating serial node to the first node. It appears as greyed out with a "recycle" logo on it. There is no preview. Again, I can't seem to select it.
There must be sumthing simple that i overlook somewhere but i cant find this simple problem in the forum.
Tutorials don't seem to address this problem. I tried comparing screens with the online tutorials and i think my settings are the same.
Can anyone help?
Nina
Nina Frost
Re: Unable to Select Node, Greyed out Box in Resolve 9.
on Dec 3, 2013 at 9:14:47 am
I decided to add in a screen grab to better explain my simple question.
Please see the node box, no nodes are selected(i can't select them) and one of them is greyed out)
Operating system, PC
Nina
Peter Chamberlain
on Dec 3, 2013 at 9:59:52 am
Hi, Double click on the node to select. use Option S (Alt S) to add a node after the current one.
If its greyed out with the recycle logo.. you may have a GPU resource issue. Lets start with one node first and make sure you can select that. Then add a second and see if that works.
Peter
Nina Frost
on Dec 3, 2013 at 10:06:47 am
Hi Peter,
Did the following,
mouse left Double click, mouse middle click, right click, failed to select.
I am able to add a new node, but as u can see the screengrab, its greyed out and i'm also unable to select.
Nina
Peter Chamberlain
on Dec 3, 2013 at 10:47:19 am
Hi, ok, please give me all your system details. OS, computer, RAM, CPU, GPU, GPU ram, etc.
thanks
Peter
Nina Frost
on Dec 3, 2013 at 11:00:40 am
OS: Windows 7 Pro
RAM: 64gig
Intel Core i7 - 4960x CPU 3.6Ghz
Card: GEFroce GTX770
Nina
Peter Chamberlain
on Dec 3, 2013 at 11:41:51 am
Mmm, can you download and install the v10.0.1 from our web support site. Have u installed the GPU card driver?
Peter
Nina Frost
on Dec 3, 2013 at 11:45:04 am
hi Peter
1) install over the existing resolve or
2) uninstall the previous resolve, reinstall the new resolve 10?
Nina
Peter Chamberlain
on Dec 3, 2013 at 12:57:51 pm
I would in install first.
Nina Frost
on Dec 4, 2013 at 4:34:14 am
Hi Peter,
Ok, let me go try that.
Nina
Nina Frost
on Dec 5, 2013 at 8:40:49 am
Hi Peter,
I have upgraded to resolve 10, here is the situation,
- I am able to select the nodes,
- I am able to preview the second, third nods...etc
- I can't see the window mask selection tool in the preview, meaning, - I can apply the mask, but i can't see where it is being applied to on the preview screen, see attached image (no selection rings)...
Please advise
Nina
Peter Chamberlain
on Dec 5, 2013 at 8:59:12 am
It looks like you have highlight turned on.
Do you have split screen on?
Try selecting the icon on the LHS bottom of the viewer.
Now that you can select nodes I think you should work through the tutorial in the manual and become more familiar with the toolset.
Peter
Nina Frost
on Dec 5, 2013 at 11:16:17 am
Hi Peter,
Split screen is on. ( Top bar, "view"-> "spilt screen") is that what you mean?
Sorry, what do you mean by "LHS" Do you mean "left hand side"?
And how does the icon look like?
Nina
Peter Chamberlain
on Dec 5, 2013 at 12:18:05 pm
Hi, these are all operational issue that I feel you will solve by reading the manual in detail. There is much to learn and so i suggest you start with the tutorial project.
You can also purchase online training for v10 from a number of sources including FXPHD.
Regards
Peter
