Multi GPU support in Davinci 10 Lite
COW Forums : DaVinci Resolve
Damon Stea
on Dec 1, 2013 at 10:46:07 pm
I have a few questions regarding the GPU compatibility on a Windows 8.1 system running Resolve Lite, and the appropriate monitoring solution to purchase.
I'm currently running DaVinci on a generic build, with a single GTX 760 2GB GPU. This is connected to an HP Dreamcolor monitor over DisplayPort, which allows 10-bit RGB output.
Also available, but not currently installed, is a 1920x1200 8-bit Dell monitor, and a GTX 570 1.28GB video card.
So the two questions are:
1) Can I use both GTX graphics cards in the same build, even though they are different models? If I can, will the total VRAM used be 3.28GB, or far less since the lowest common denominator is the GTX 570?
2) As far as I understand, I still need an additional monitoring solution even with 2GPUs - but I will be monitoring over either HDMI or DisplayPort. What is the lowest cost card or USB 3.0 monitoring solution from Blackmagic that would support this setup?
Peter Chamberlain
Re: Multi GPU support in Davinci 10 Lite
on Dec 2, 2013 at 1:10:39 pm
Hi, use the 570 for UI GPU, connect to the Dell, the 760 for processing. Do not connect any monitors to the 760. If you can, purchase a Bmd SDI video card and a HDLink with display port output to connect to the dream color 10 bit monitor.
Peter
