aliasing on text davinci resolve 10
COW Forums : DaVinci Resolve
mikee carpinter
on Nov 17, 2013 at 5:30:38 pm
I have just done a project where where I did the online in resolve 10.
Everything worked great until I had to add some very simple text to the end of the commercial and the text looked aliased and steppy.
Is there something I need to do to get smooth edges on the text?
Seems simple but cannot fix.
Cheers
Juan Salvo
Re: aliasing on text davinci resolve 10
on Nov 17, 2013 at 8:49:44 pm
Did you look at the text on an external monitor or on the GUI screen? What about in the rendered files?
http://JuanSalvo.com
http://theColourSpace.com
mikee carpinter
on Nov 17, 2013 at 8:56:24 pm
On monitor as well as in Gui
Then I exported DPX sequence for DCP and got a call from the post house rejecting the file because the text was aliasing.
Juan Salvo
on Nov 17, 2013 at 9:08:43 pm
Can you give more details. What resolution? What font? Was there any output scaling applied to the timeline?
mikee carpinter
on Nov 18, 2013 at 9:45:06 pm
2K 16:9 resolution
HELVETICA NEUE
No output scaling.
You want me to do a screen grab?
Thanks Juan
Mikee
Juan Salvo
on Nov 19, 2013 at 4:18:47 am
2K 16:9... what is the target display for that? 2048x1152, wrong aspect if it's theatrical, wrong resolution for broadcast. Better than a screen grab would be a rendered frame.
Jonathan Bigler
on Apr 7, 2014 at 3:46:38 pm
Hi Mikee,
I run into the same issue, I had no scaling, 1080p timeline, monitor with the native resolution, nothing fancy.
I tried several fonts, same issue all over.
Then I tried to turn off the shadow effect which was there by default, and boom, smooth edges.
Annoying little bug, it's useful with shadows. But those edges were really ugly.
