Render cache
COW Forums : DaVinci Resolve
David Baud
Render cache
on Nov 11, 2013 at 5:34:35 pm
I am working in Resolve 10 in a project with 2 timelines.
When using render cache, if I switch to the other timeline, I loose all my render cache from the first timeline.
Is there a way to make sure the render caches are saved so someone does not have to recalculate them all the time??
David Baud
Post & VFX
KOSMOS PRODUCTIONS
Denver - Paris
http://www.kosmos-productions.com
Sascha Haber
Re: Render cache
on Nov 11, 2013 at 8:07:45 pm
no ;)
Still not..
Even if the request is as old as Resolve by now.
But you could render the whole thing using the "professional workflow" ad then create a playback timeline with the outputs.
We do this on systems that are to slow to work in RT from RED files or have no external GPUs.
A slice of color...
Resolve 10.0.0.073 , Smoke 2013 EXT
Colorist / VFX / Aerial footage nerd
http://vimeo.com/saschahaber
David Baud
Re: Render cache
on Nov 12, 2013 at 3:29:13 pm
Thanks Sascha... yes it is too bad that Render Cache is not working better. I also wish there would be an easy way to deselect all "Mark clip for render cache" from clips, so at least you could work in a short sequence.
[Sascha Haber] "But you could render the whole thing using the "professional workflow""
Are you referring to a specific workflow? any link?
David Baud
Post & VFX
KOSMOS PRODUCTIONS
Denver - Paris
