Flag single shots when timeline is from a single source clip?
COW Forums : DaVinci Resolve
Nat Jencks
on Nov 8, 2013 at 6:10:17 pm
If your timeline is from a single source clip, e.g. you have used the import pre conformed EDL to notch a flattened render, is there a way to flag a single clip? Whe I place a flag, it goes to every source clip. I can use marked but they are not useful since I can't see them from the color window.
-Nat
Peter Chamberlain
Re: Flag single shots when timeline is from a single source clip?
on Nov 9, 2013 at 1:02:23 am
No, user a marker in the edit page.
Peter
Nat Jencks
on Nov 9, 2013 at 1:05:22 am
thanks Peter, understood. consider this is minor feature request :)
Flagging shots (in such a way that they can be seen in the color page while working is quite important to me (and I'm sure others), and I still quite a few jobs grading from a single precomformed render notched with an EDL.
Thanks for the quick reply :) !
best-
-Nat
Marc Wielage
on Nov 9, 2013 at 1:34:48 am
[Nat Jencks] "If your timeline is from a single source clip, e.g. you have used the import pre conformed EDL to notch a flattened render, is there a way to flag a single clip?"
If you use a local grade rather than a remote grade, or create a new Version, it seems to me that the clips would no longer be linked and then you'd be able to flag individual clips that have been cut up in the conform window.
Nat Jencks
on Nov 9, 2013 at 2:00:49 am
Yes I would have though so, but this does not seem to be the case.
This issue is not strictly related to pre conformed EDL workflow either, it would be nice if adding a flag only added the flag to the single instance of the local version, unless the shots are gouged in which case it would make sense to add the flag to all shots grouped right?
best
-Nat
Danny Duchesneau
on Dec 12, 2014 at 1:24:50 am
This is totally retarded.
