BMCC Raw Cine DNG: Power Window & Qualifier malfunction
COW Forums : DaVinci Resolve
Francois Driessen
on Nov 5, 2013 at 9:51:52 pm
Hi there, guys.
I've run into this in both R9 & R10b3. Hope someone out there can help...
When pulling a qualifier and combining that with a power window, the qualifier should be limited to parameters of the power window. This works perfectly with all my ProRes media.
However, when grading Cine DNG raw clips the only area of the qualifier that is active is in the are that falls in the zone of the feather of the power window… Try it…!
Anyone out there had a similar experience? Does it happen with RedRAW too? Any ideas on how to fix this are very welcome…
Francois
FireTrigger Inc.
http://firetrigger.com
Margus Voll
Re: BMCC Raw Cine DNG: Power Window & Qualifier malfunction
on Nov 6, 2013 at 5:26:50 am
Hi.
Have not seen this.
Just yesterday i was grading BMCC raw and all was perfect.
Margus
http://iconstudios.eu
https://vimeo.com/iconstudioseu/videos
DaVinci 9, OSX 10.7.4
MacPro 5.1 2x2,93 24GB
GTX 470 / Quadro 4000
Multibridge 2 Pro
Francois Driessen
on Nov 6, 2013 at 4:37:44 pm
Thanks, M
I tested again. Issue is only when I connect my key out from first node to key in from 3rd node for outside key. I sometimes want to grab key info from the raw node before I do additional nodes, and use that later down-stream.
Try that?
But I can work around it, I guess.
Francois
FireTrigger Inc.
Margus Voll
on Nov 6, 2013 at 4:39:29 pm
Could you drop screenshot of the nodes?
Margus
Multibridge 2 Pro
Francois Driessen
on Nov 6, 2013 at 4:50:29 pm
Margus Voll
on Nov 6, 2013 at 5:51:55 pm
So how did it work for you ?
As fas i i know it should do nothing until you make key out of the source?
Margus
Multibridge 2 Pro
