Render frame rate options R9 vs. R10
COW Forums : DaVinci Resolve
Kevin Cannon
on Oct 30, 2013 at 1:03:07 am
In Resolve 9, I have a project that is set to "timecode calculated at 24," and it gives me the drop-down option to render out 23.98 or 24. After moving the project to R10b3, I'm only getting the option to output at 24.
Testing with an empty project, it looks like R10 only offers exactly the frame rate that is in the conform setting, which seems like a disadvantage. Is this how R10b3 is behaving for everybody?
Cheers
KC
Prehistoric Digital
Rohit Gupta
Re: Render frame rate options R9 vs. R10
on Oct 30, 2013 at 11:28:23 am
Hi Kevin,
We'll have the option to choose between 23.98 and 24 in the final release of V10. It's a beta limitation.
Regards,
Rohit
Kevin Cannon
on Oct 30, 2013 at 2:16:08 pm
Great, thanks Rohit.
KC
Prehistoric Digital
Joakim Ziegler
on Nov 3, 2013 at 3:51:08 am
If you're rendering to Quicktime, you can use CinemaTools in the meantime to just change the framerate of the quicktime file from 24 to 23.976.
Joakim Ziegler - Postproduction Supervisor
