Xml Issues
COW Forums : DaVinci Resolve
Nina Sargsyan
Xml Issues
on Oct 24, 2013 at 11:50:40 pm
Hey everyone, I just did an XML from Premiere to Resolve, that was fine everything worked out correctly. But on the way back I did a Final Cut XML from Resolve and when I open the sequence half of my clips are missing. I have posted a picture below if anyone could give some insight that would be great. Im on a windows system.
Eric Johnson
Re: Xml Issues
on Oct 28, 2013 at 4:19:31 pm
Are the SHADED portions of the timeline the parts that are missing?
If so, it looks like you may not have rendered with "Use Unique File names" checked. This will cause multiple instances of a clip to be overwritten each time it is rendered.
Hope that helps.
eric b johnson
online editor | colorist | workflow
Nina Sargsyan
Re: Xml Issues
on Oct 30, 2013 at 11:52:38 pm
It worked great, Thanks!
