Fastest node replication
COW Forums : DaVinci Resolve
james Lackleter
on Oct 18, 2013 at 1:28:00 am
So I graded before I cut this time. How can I copy the nodes to my xml import the fastest. Also is it possible to export a 3840 res xml into smoke and export in full 4080? Thanks
james Lackleter
Re: Fastest node replication
on Oct 19, 2013 at 4:39:28 am
Hello there, any help? I'd really prefer not to copy and paste my nodes? Is there anyway to do this on import? I'm using a new workflow so I'm a little at a loss here.
Chris Martin
on Oct 20, 2013 at 6:13:45 am
You can use color trace if your source clips are the same. Different ways to color trace described in manual.
