"disble input sizing" option gone for XML/AAF scaling?
COW Forums : DaVinci Resolve
Toby Tomkins
on Oct 9, 2013 at 2:15:57 pm
Is this gone or somewhere else. I'd normally right click on a clip in the timeline in the Color Tab and check this if I wanted to remove offline scaling. Thanks for any help!
brandon thomas
Re: "disble input sizing" option gone for XML/AAF scaling?
on Oct 9, 2013 at 3:07:47 pm
It's under the Edit page now. Click on a clip in the timeline, and then hit the ltitle icon with a wrench and paint brush and it will reveal those parameters, which you can click the dot to disable, or zero out.
Toby Tomkins
on Oct 9, 2013 at 4:34:35 pm
Thanks! Wish the option was still there in the dropdown though!!
Andrew Shtern
on Nov 5, 2013 at 4:19:24 pm
+1 to that
why is "Use sizing information" is always checked (and grayed out, so unable to uncheck), and there is no other simple way to ignore sizing information for all clips? or you just supposed to click this invisible yellow dot on clip-by-clip basis?
is it just a bug or another "new and convenient" feature?
also, is there a way to wipe with reference clip while adjusting input sizing, like it was in v8?
Andrew Shtern
Editor/Colorist
The Coffeepost @Kiev, UA
