Crashing (pinwheel) in Conform Tab ONLY. Resolve 9 Lite
COW Forums : DaVinci Resolve
Johnathan Throbins
on Oct 3, 2013 at 11:47:41 pm
I loaded an old DRP file to change the edit a hair and re-render. I'm on a different system and a different hard drive but same file structure. I changed the hard drive name to match the old one and clips link up fine, Color tab and Media Pool tab are fine and both playback fine. All grades are alive and well. Problem is, every time I go to the conform tab and scroll down to where the clips are seen it crashes/freezes on the spinning pinwheel of death. Once during playback in color tab I got an audio error and the clips all went black, I don't know if that's related. Didn't happen when I reloaded the project.
I tried re-assigning the cachclip directory in case that had any junk in it, it didn't put anything into the new one. I'm not sure what the point was. Maybe that's just for when you add things to the media pool...
Is there anything else I can clean out or do to help figure this out? I really need to fix the conform on this project!
________
OSX 10.6.8
Resolve Lite 9.1.6
2.26Ghz 8 Core Mac Pro
12GB Ram
Monitor GT 120
CUDA GTX 285
