Simple Node Problem
COW Forums : DaVinci Resolve
Rajarshi Basu
Simple Node Problem
on Oct 1, 2013 at 11:45:31 am
I'm new to Resolve. Presently I am facing a problem where the same shot is in 2 parts in the sequence. But different light conditions.
But the grade is getting applied to both the shots. Even when I am applying a node, its getting applied to both the shots. How do i apply different grade if the clip is same but edited in 2-3 shots in the time line?
Thanks !
Margus Voll
Re: Simple Node Problem
on Oct 1, 2013 at 12:18:21 pm
You should look for linked clips in the manual.
Margus
http://iconstudios.eu
https://vimeo.com/iconstudioseu/videos
DaVinci 9, OSX 10.7.4
MacPro 5.1 2x2,93 24GB
GTX 470 / Quadro 4000
Multibridge 2 Pro
Andy Winter
on Oct 2, 2013 at 8:11:48 am
this question has been answered a hundred times before. right click on any clip
in the timeline and chose: use local grades...
Rajarshi Basu
on Oct 2, 2013 at 8:23:32 am
Thanks :) yes I looked into the manual and just did that...solved.
andrew sableton
on Oct 3, 2013 at 7:46:14 pm
I vote to end the failed experiment of dividing the DAVINCI forums into "Basics and Configuration" and the main "Forum".
S
