Resolve 10b2 color and export questions
COW Forums : DaVinci Resolve
Eric Chase
on Oct 1, 2013 at 12:37:49 am
(Apologies if this has been asked before in DR10b1)
1) Resolve used to remember all the grades from a particular clip. As you graded 1 clip, the other edits form that clip would also get graded. BR10B2 default each grade separately.
2) Related to Q1: Master grade doesn't appear to work. If I duplicate a timeline, or import the same XML again, the grades are not there.
3) After I render for FCP7 export, sometimes the edits are short 1 frame. (1080p/23.976fps)
4) After I render for FCP7 export, opacity fades come up as 0% for the whole clip.
5) slow motion doesn't work. Wrong timecode is affected.
Thanks for your time.
John Tissavary
Re: Resolve 10b2 color and export questions
on Oct 2, 2013 at 10:56:00 pm
Page 167 of the DaVinci Resolve V10 manual tells you everything you need to know to get master timelines in your vl0 project.
John
John Tissavary | colorist | owner
The Post Collective
