Linear scans in Resolve
COW Forums : DaVinci Resolve
Eugene Lehnert
on Sep 21, 2013 at 6:48:32 am
I have 2k linear DPX scans I want to color grade. I can't play them back in real-time though. I want to convert them to ProRes4444 HD files. What's the best way to do that? They are 16-bit right now. Do I need to put them through a LUT to properly convert them to Rec709 aka properly gamma encoding the files so I retain all the proper bit depth when I go to HD?
Joakim Ziegler
Re: Linear scans in Resolve
on Sep 21, 2013 at 8:28:44 pm
Converting them to another color space will probably clip them. You should just convert with no LUT.
Joakim Ziegler - Postproduction Supervisor
Robert Houllahan
on Sep 22, 2013 at 7:02:39 am
Realistically the scans are probably 12-bit in a 16bit wrapper, as not many CCD's or CMOS sensors go beyond 12-bit linear. I would just make a flat pass unscaled render to ProRes444 which is a 12-bit capable format.
-Rob-
Robert Houllahan
Director / Colorist
Cinelab Inc.
http://www.cinelab.com
2X Resolve 18Tb and 24Tb Dual GTX580's HD Telecine and 4K Film scanner plus a film lab.
