Migrating project with LUTs that are no longer installed
COW Forums : DaVinci Resolve
Toby Tomkins
on Aug 27, 2013 at 1:27:51 pm
I have an old project that used some LUTs that I no longer have installed, which I am trying to migrate over to a new machine.
I have tried moving the entire database (via backup/restore) and also exporting the project (ticking the LUT box when doing so). Neither methods seem to migrate across the old LUT.
Any ideas?
Toby
Toby Tomkins
Re: Migrating project with LUTs that are no longer installed
on Aug 27, 2013 at 2:58:50 pm
It's worth noting I applied the old LUT via a node and despite the LUT not being installed anymore, is still being aplied by the node in the old project!
Eric Johnson
on Aug 27, 2013 at 4:44:11 pm
Are you not able to create a LUT from a Node/Correction? If the non existent LUT is still being applied correctly, you could try opening the project in "Read Only" mode, disabling all corrections but the LUT and generating a new one...
May not work, but if it does you have the LUT you no longer have...
eric b johnson
online editor | colorist | workflow
Toby Tomkins
on Aug 27, 2013 at 5:03:35 pm
I thought of that but I've never found DaVinci's LUT generation to be 100% reliable, especially when using a complex 3D LUT like this one (Alexa LogC to Technicolor Vision 3 250D log film scan LUT, that's increasing colour separation and is fragile as-is, without DaVinci ripping it which might introduce further problems). I'll give it a go if there's no other way and report back.
Eric Johnson
on Aug 27, 2013 at 5:24:22 pm
What about stripping everything but the LUT and saving the Node to the Still Store?
eric b johnson
