Sharing LUTs between systems on a Resolve Database server
COW Forums : DaVinci Resolve
Kevin Cannon
on Aug 21, 2013 at 12:45:28 am
Is there a function of Resolve or Resolve database server that allows the sharing or syncing of LUTs on multiple machines?
For example, if we use a custom LUT for Alexa on one work station, currently we copy it to each workstation and refresh the lists. Sometimes we fail to get everything identical on all systems, and need to render something off on a different station. It would be convenient if that information could travel with the database server. Any such thing?
KC
Prehistoric Digital
Juan Salvo
Re: Sharing LUTs between systems on a Resolve Database server
on Aug 21, 2013 at 1:21:00 am
you could do a little rsync script between stations.
color/post/workflow
http://JuanSalvo.com
Dan Moran
on Aug 21, 2013 at 2:40:59 pm
not sure if it works on mac but on linux we use a alias folder that can link folders so resolve thinks its looking at the cinespace folder but its actuallly a folder on our san that all machines can see
Dan Moran
Colourist
Smoke & Mirrors: London
http://www.danmorancolor.com/blog
Juan Salvo
on Aug 21, 2013 at 3:13:58 pm
yeah symlinks would work on the mac as well.
color/post/workflow
Kevin Cannon
on Aug 23, 2013 at 6:33:05 pm
Thanks guys!
Resolve couldn't follow an alias created using the OS, but creating a symlink with the ln -s terminal command worked properly.
For reference, I used this command:
Theater1:~ Username$ ln -s (drag the Shared SAN path here) /Library/Application Support/Blackmagic Design/DaVinci Resolve/LUT
Prehistoric Digital
