DaVinci deck output -> AJA KiPro
COW Forums : DaVinci Resolve
Danny Thompson
on Aug 15, 2013 at 4:33:46 pm
I'm looking into using DaVinci as a realtime legalization system.
I have a KiPro and have successfully edited stuff on to it from FCP but can't seem to get it working with DaV despite trying a lot of different configurations on each end.
Does anyone here have experience getting the two to work together?
Peter Chamberlain
Re: DaVinci deck output -> AJA KiPro
on Aug 16, 2013 at 1:30:26 am
DaVinci Resolve supports the BMD range of video capture and playback devices.
Not the Ki.
Peter
Danny Thompson
on Aug 16, 2013 at 2:35:10 am
But isn't it supposed to support decks in general?
Oh well. Back to the FCP broadcast safe filter.
Peter Chamberlain
on Aug 16, 2013 at 6:51:48 am
Re-reading my post I see I didn't answer your question. You didn't mention your video capture card, and I meant to say, you need a BMD card assuming you had AJA connected to the Ki-Pro.
So, which BMD card do you have on your Resolve and is it SDI you are trying to connect too? Do you have the RS-422 connected for control?
Peter
Danny Thompson
on Aug 16, 2013 at 12:48:21 pm
Haha, yes, actually saying what gear it is always helps...
Card is a Decklink Extreme HD, Resolve 8, and I am using RS422 control and SDI for video IO.
When I put bars up on the KiPro I get video in. I can't get it to detect it otherwise. I turn off the bars before starting to record. Once I start recording, Resolve doesn't actually output anything over SDI (I'm monitoring it two different ways, I'm sure).
