workflow with Red footage and PP CS6
COW Forums : DaVinci Resolve
Ryan Hansen
on Aug 8, 2013 at 2:36:34 pm
Hey everyone,
I've having an issue with going from PP CS6 to Resolve 9 with Red footage. As a test I cut a real simple timeline in premiere with just a single clip that I cut in half.
I then saved the file as an . AAF and selected "save as legacy"
I opened Resolve and imported the .aaf file. Immediately it warns me that files are missing and if I would like to search for them. So I do and go directly to where that 1 and only file is located and clear the message.
When I'm in the conform tab I can see the clip that was in my premiere timeline and I can see the cut i made. However, the first half of the cut is there yet the second half is offline.
I in fact have have this problem with every .aaf file I've imported.
I was told that .aaf was the way to go with going from premiere to resolve? Should I try other formats?
Laco Gaal
Re: workflow with Red footage and PP CS6
on Aug 8, 2013 at 4:48:58 pm
If you don't have speed ramps, try a simple EDL.
Import the source footage into Resolve, then import the EDL, and they will find each other hopefully
