Video dissolves when source media is flattened quicktime
COW Forums : DaVinci Resolve
jim bachalo
on Aug 6, 2013 at 1:20:43 am
Haven't been able to apply any cross dissolve effects in my project. Am using scene detection on a flattened quicktime.
Will I need to go back into my NLE and export individually just those clips that need a cross dissolve?
Local is the new global
Josh Petok
Re: Video dissolves when source media is flattened quicktime
on Aug 6, 2013 at 4:14:56 am
If you preconform you sequence with an EDL, all the dissolves will be in place.
Josh Petok
Online | Color
JoshPetok.com
TheCurrentCut.com
Margus Voll
on Aug 6, 2013 at 9:57:10 am
I think he meant if he has one long file that is cut up by scene cut.
Margus
http://iconstudios.eu
https://vimeo.com/iconstudioseu/videos
DaVinci 9, OSX 10.7.4
MacPro 5.1 2x2,93 24GB
GTX 470 / Quadro 4000
Multibridge 2 Pro
jim bachalo
on Aug 6, 2013 at 1:25:54 pm
Yes to the above. Using scene detection. Instead of deleting my dissolves BEFORE exporting to flattened QuickTime, should I instead leave them in, and manually cut down the middle?
I would then need to recreate them in Resolve.
This has been suggested elsewhere but I thought it made more sense to delete the dissolves first.
Josh Petok
on Aug 6, 2013 at 1:45:07 pm
Preconforming will take a flattened QuickTime (even with dissolves) and slice it up based on an EDL. However, since you've already graded it, that wouldn't do you much good. I think recreating the dissolves in resolve is you best bet, but if it comes up again, I'd use the preconform workflow if possible.
Josh Petok
Online | Color
JoshPetok.com
TheCurrentCut.com
